How to export my model as .json? Does Cubik Studio automatically remove hidden faces?
And how to move objects (converted from OBJ) down? I can't click it because it doesn't have any element.
Saving as .json? [Solved]
Re: Saving as .json?
to export your mode as a json make sure the model is made of elements and press file -export it should say .json if it that is not the case press the filetype and chance it to json
hidden elements are a visual thing for cubik studio it self if you make a hiiden element and export it the modle will not hidden in game if im right
try using the Arrow keys on your keyboard to move your model down on the screen that contains a side view those ansers should help you further
a life Without cubik is no Life
Re: Saving as .json? [Solved]
To export as json a voxel model you must convert voxels to elements first (as its stated in the message box if you try to export json with only voxels).
To convert voxels to elements, in "Voxel" editmode select ... > Convert
