texture meshup  [Solved]
texture meshup
Post by weshuiz13 » 14 Jan 2017, 09:45
for some reason i get realy messy models when using elemnts only 1 of them is a side of the element will apear in static/noice the other problem is how cubuik stuio marks the element with a random color confusing me when i apply a texture
aswell as trouble with the hight view when creating a element it will not be viseble when in the top row below or under only the middle row will render the element from top view oh btw fix your screenshot foto system i dont know how to include a picture / not working
proof of glich
proof of glich
a life Without cubik is no Life
weshuiz13
Re: texture meshup
Post by CaptainGalax » 14 Jan 2017, 10:23
weshuiz13 wrote: 14 Jan 2017, 09:45 for some reason i get realy messy models when using elemnts only 1 of them is a side of the element will apear in static/noice the other problem is how cubuik stuio marks the element with a random color confusing me when i apply a texture
You need to set UV_Mapping, there are no UV on the faces.
CaptainGalax
Re: texture meshup
Post by weshuiz13 » 14 Jan 2017, 10:26
i have edited my post a screenshot should now be included as a atachmend
weshuiz13
Re: texture meshup
Post by CaptainGalax » 14 Jan 2017, 10:27
And you can disable Random Colors on Tools --> Preferences --> Display --> Elements Color
CaptainGalax
Re: texture meshup
Post by weshuiz13 » 14 Jan 2017, 13:15
im still encountering my problem uv mapig is not the trouble maker
this glich happens with every element that is renderd the only time this do not apear if the elemetn is converted from a obj o voxel
what is the problem with my models and when the problem seems to be fixed all i need 2 do is move the model and i get the problem again
when i export the model it looks fine but will look meshed up in only studio
weshuiz13
Re: texture meshup  [Solved]
Post by Sphax » 14 Jan 2017, 15:12
The problem is due to UV Snap option which is enabled by default and which clamp UV coordinates to the border of middle zone. So if your element is outside middle zone, you'll get such glitch.
It's not a bug but it will not happen anymore on 2.6 because UV Snap calculation is working differently.
To workaround that in the meantime, edit your elements UVs or move your elements in middle zone
Re: texture meshup
Post by weshuiz13 » 14 Jan 2017, 18:18
ty know i know the problem only disableing uv snap will not fix the element but i hope the update is comming soon
weshuiz13
Re: texture meshup
Post by Sphax » 14 Jan 2017, 21:47
You can fix that by editing UVs manually
