Post
by xxBurn77xx » 13 Jan 2017, 14:13
Hey!
I'm new in 'Making 3D-Models'
and my problem is: I made a new block, which have a normal glass texture and other textures.
When I have the block in the hand/on floor, it's looking like:
http://imgur.com/a/TwEiT and when I place the block, it's looking like:
http://imgur.com/a/D7K6h
How can I fix this? Is that normal?
Sorry if something in this topic is wrong; I mean grammatical (I'm from Germany)
Have a good day!
Bye!
xxBurn77xx
Post
by CaptainGalax » 13 Jan 2017, 16:16
xxBurn77xx wrote: 13 Jan 2017, 14:13
Hey!
Have a good day!
Bye!
Verwendest du einen Transparenz Block? Z.B: Glass,Zaun. Oder schreib einfach welche "Blockstate" (Block) du benutzt!;)
CaptainGalax
13 x | 18 x
Post
by Sphax » 13 Jan 2017, 21:46
Only several blocks are able to use transparency in textures such as glass, beacon, grass, leaves ...
- Admin
70 x | 223 x
Post
by xxBurn77xx » 14 Jan 2017, 12:23
oh I use the Redstone-Block. That makes sense....
xxBurn77xx
Post
by CaptainGalax » 14 Jan 2017, 12:49
xxBurn77xx wrote: 14 Jan 2017, 12:23
Du kannst auch die Blockstate, so bearbeiten das dein Block Transparenz hat.
CaptainGalax
13 x | 18 x
Post
by Sphax » 14 Jan 2017, 15:10
@CaptainGalax I don't think we can force transparency on blocks with blockstate. If that's the case, I would like you to post an example about it!
- Admin
70 x | 223 x
Post
by CaptainGalax » 14 Jan 2017, 15:37
Sphax wrote: 14 Jan 2017, 15:10
mhm i heard of that, well i found only this;
http://minecraft.gamepedia.com/Block_states
CaptainGalax
13 x | 18 x
