Shape is viewable but not textures  [Solved]
Post by EnderMatrul » 12 Jan 2017, 21:20
Hello! I Made a 3d model of the WW1 Lewis gun, But when I converted the voxels to elements, all the textures disappeared, then when I exported it into minecraft, It was viewable and you could see the 3d shape, but the texture was just black and white.
I undid the conversion, And the textures were back, But how do I convert it to elements with all the textures?
EnderMatrul
Re: Shape is viewable but not textures
Post by Sphax » 13 Jan 2017, 00:02
Can you post the cubik file and tell the version you are using?
Post by EnderMatrul » 13 Jan 2017, 00:57
Okay, Lewis gun is the element file and voxel lewis gun is the non converted one(Still voxels)
And im using the latest I'm pretty sure, I got cubik just yesterday
VoxelLewisGun.cubik
(116.8 KiB) Downloaded 213 times
LewisGun.cubik
(97.86 KiB) Downloaded 214 times
EnderMatrul
Post by Sphax » 13 Jan 2017, 22:09
Converting voxels to elements worked on my side and loading your model already converted to elements is working well and everything is textured/colored
Post by EnderMatrul » 13 Jan 2017, 22:19
Why is it not working for me? Also, Maybe you could send me the successful conversion just incase we cant solve why it doesn't work for me?
EnderMatrul
Re: Shape is viewable but not textures  [Solved]
Post by EnderMatrul » 13 Jan 2017, 22:49
Nvm, Found the problem, thanks!
EnderMatrul
Post by Sphax » 13 Jan 2017, 23:31
What was the problem?
