I've made some textures of e.g. a flower pot or a ladder and the textures of sides are just transparent. I don't know how to fix that. Can you tell me which setting i must have set?
Thank you
Textures disappear
Re: Textures disappear
I texture on side are transparent it's either the UV mapping is wrong or the face(s) are hidden. In both case edit the element properties
Select element > Go in Element edit-mode > Click element faces button > Check that all faces are enabled > Go in element UV mapping > Check if UV of each face is ok (in a non transparent texture zone)
Heres the easy fix. FIRST. If your texture has transparent pixels in it, which it looks like it would, you must make sure that the element with the invisible face is on a place with color in the UV editor. If it has color but is still invisible like this continue to this next step. In Cubik select the element that has the invisible faces then, in the panel on the right that has the list of elements right click the one you selected, go to "Faces" then "enable" then enable the face that is invisible. in this picture it appears that the "top" faces are invisible. Hope this helps!
My problem is a little different.
I'm editing an End rod to look like a hanging lantern.
If you place it under an iron fence or if it is floating - It looks great!
But when I place it under a block, the base and frame of the lantern disappear.
Not sure what I'm missing here
I also get this alert when trying to exporting
- Agt_Montag
- Likes: 5 x | 2 x
- Agt_Montag
- Likes: 5 x | 2 x
You probably have a culling issue. To fix that, verify the elements which are disappearing in game and modify their culling parameter. If you are not sure what to do, you can simply remove all culling parameters (in Elements list, this is quite fast to achieve)
