How to use the models in Minecraft  [Solved]
Post by bigtryguy » 29 Dec 2016, 18:51
Hello.
I'm new to using Cubik Studio, and have just finished my first model and would like to use it in a Minecraft resource pack. I have successfully exported the .json file and moved it to the models folder, however, the model is unchanged in-game. I have looked around some, but I can't find any up to date information on how. Would anyone be able to find a tutorial, or explain it?
Thanks.
bigtryguy
Re: How to use the models in Minecraft
Post by CaptainGalax » 30 Dec 2016, 09:34
bigtryguy wrote: 29 Dec 2016, 18:51 Hello.
Thanks.
What block did you use? Have you the right Name? Have the .json a error?
CaptainGalax
Post by bigtryguy » 30 Dec 2016, 21:43
CaptainGalax wrote: 30 Dec 2016, 09:34 What block did you use? Have you the right Name? Have the .json a error?
I'm trying to use it to replace a wood log. The name I have the file saved as is log_oak.json, the same as the texture file. Its saved in the assets/minecraft/models/blocks. I'm not getting any errors, its just displaying the default wood model. I'm guessing I need a blockstates file or something, but as I said, I couldn't find any info on it. Thanks for the help.
bigtryguy
Re: How to use the models in Minecraft  [Solved]
Post by Ryugo0 » 30 Dec 2016, 23:14
bigtryguy wrote: 30 Dec 2016, 21:43
The right name for oak log is "oak_log.json" and not "log_oak.json"
And your json file must be in assets/minecraft/models/block NOT "/blockS" :D
Ryugo0
Post by bigtryguy » 31 Dec 2016, 01:44
Ryugo0 wrote: 30 Dec 2016, 23:14
I'm dumb. Sorry about that, and thanks again.
bigtryguy
