I'm very new to Cubik and I'm attempting to create a weapon for minecraft. Now I modeled what I wanted, and I made it look how I wanted in preview. I exported the .json file into my resource pack, but the weapon does not look how I wanted it to look.
Here are the pictures that I think will help: http://imgur.com/a/X73fi
The top picture is in Cubik and the bottom one is in-game.
Please help me get this fixed. I will happily release more information if that is needed in order to fix this issue.
Problem with Model Orientation, Color, and Size
- AgentZach1
Re: Problem with Model Orientation, Color, and Size
Make sure you check "Export Settings" in Cubik when setting the views.
I have that done, now only 2 textures are working correctly, none of my other ones are. The 3rd person still looks like it did in my first picture.Make sure you check "Export Settings" in Cubik when setting the views.
What settings should I have on to make sure that I have my model how I want it to look? Also the color is plain white while in Cubik I specified color.
- AgentZach1
Hard to help you more without .cubik or at least JSON
Here's my code for the .JSON file. I don't know how to attach my .cubik file.
I should also mention that I'm using Labymod 1.8.8 for the texture pack.
"__comment": "Designed by AgentZach1 with Cubik Studio - https://cubik.studio",
"ambientocclusion": false,
"textures": {
"particle": "blocks/obsidian",
"texture": "blocks/clay",
"texture1": "blocks/hardened_clay_stained_purple",
"texture2": "blocks/iron_block"
"elements": [
"__comment": "Cube6",
"from": [ 7.498973, 16.49963, 7.999371 ],
"to": [ 8.498974, 17.49963, 11.49937 ],
"faces": {
"down": { "uv": [ 12, 9, 8.5, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 12, 8, 8.5, 7 ], "texture": "#particle", "cullface": "up", "rotation": 270 },
"north": { "uv": [ 8, 4.5, 7, 3.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 4.5, 8, 3.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 8.5, 3.5, 12, 4.5 ], "texture": "#particle" },
"east": { "uv": [ 4, 3.5, 7.5, 4.5 ], "texture": "#particle" }
"__comment": "Cube7",
"from": [ 7.500682, 15.50009, 8.000044 ],
"to": [ 8.500683, 16.50009, 12.00004 ],
"faces": {
"down": { "uv": [ 12.5, 9, 8.5, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 12.5, 8, 8.5, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 5.5, 7, 4.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 5.5, 8, 4.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 8.5, 4.5, 12.5, 5.5 ], "texture": "#particle" },
"east": { "uv": [ 3.5, 4.5, 7.5, 5.5 ], "texture": "#particle" }
"__comment": "Cube8",
"from": [ 7.500322, 15.49922, 6.999476 ],
"to": [ 8.500322, 17.99922, 9.499476 ],
"faces": {
"down": { "uv": [ 8.5, 9, 7.5, 8 ], "texture": "#particle", "cullface": "up", "rotation": 90 },
"up": { "uv": [ 8.5, 8, 7.5, 7 ], "texture": "#particle", "cullface": "up", "rotation": 270 },
"north": { "uv": [ 8, 5.5, 7, 3 ], "texture": "#particle", "cullface": "up", "rotation": 180 },
"south": { "uv": [ 9, 5.5, 8, 3 ], "texture": "#particle", "cullface": "up", "rotation": 180 },
"west": { "uv": [ 7.5, 3, 8.5, 5.5 ], "texture": "#particle", "cullface": "up" },
"east": { "uv": [ 7.5, 3, 8.5, 5.5 ], "texture": "#particle", "cullface": "up" }
"__comment": "Cube9",
"from": [ 7.500206, 15.99999, 10.50018 ],
"to": [ 8.500206, 16.49999, 13.00018 ],
"faces": {
"down": { "uv": [ 13.5, 9, 11, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 13.5, 8, 11, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 5, 7, 4.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 5, 8, 4.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 11, 4.5, 13.5, 5 ], "texture": "#particle" },
"east": { "uv": [ 2.5, 4.5, 5, 5 ], "texture": "#particle" }
"__comment": "Cube11",
"from": [ 7.500455, 14.99929, 10.49952 ],
"to": [ 8.500455, 15.99929, 13.49952 ],
"faces": {
"down": { "uv": [ 14, 9, 11, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 14, 8, 11, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 6, 7, 5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 6, 8, 5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 11, 5, 14, 6 ], "texture": "#particle" },
"east": { "uv": [ 2, 5, 5, 6 ], "texture": "#particle" }
"from": [ 7.499983, 14.50063, 13.49971 ],
"to": [ 8.499983, 15.50063, 13.99971 ],
"faces": {
"down": { "uv": [ 14.5, 9, 14, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 14.5, 8, 14, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 6.5, 7, 5.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 6.5, 8, 5.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 14, 5.5, 14.5, 6.5 ], "texture": "#particle" },
"east": { "uv": [ 1.5, 5.5, 2, 6.5 ], "texture": "#particle" }
"__comment": "Cube10",
"from": [ 7.499466, 14.0009, 12.50066 ],
"to": [ 8.499466, 15.0009, 14.50066 ],
"faces": {
"down": { "uv": [ 15, 9, 13, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 15, 8, 13, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 7, 7, 6 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 7, 8, 6 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 13, 6, 15, 7 ], "texture": "#particle" },
"east": { "uv": [ 1, 6, 3, 7 ], "texture": "#particle" }
"from": [ 7.499438, 15.99961, 6.000041 ],
"to": [ 8.499438, 17.49961, 7.000041 ],
"faces": {
"down": { "uv": [ 7.5, 9, 6.5, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 7.5, 8, 6.5, 7 ], "texture": "#particle", "cullface": "up", "rotation": 270 },
"north": { "uv": [ 8, 5, 7, 3.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 5, 8, 3.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 6.5, 3.5, 7.5, 5 ], "texture": "#particle" },
"east": { "uv": [ 8.5, 3.5, 9.5, 5 ], "texture": "#particle" }
"__comment": "Cube12",
"from": [ 7.499217, 14.99957, 5.500398 ],
"to": [ 8.499216, 16.49957, 7.000398 ],
"faces": {
"down": { "uv": [ 7.5, 9, 6, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 7.5, 8, 6, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 6, 7, 4.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 6, 8, 4.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 6, 4.5, 7.5, 6 ], "texture": "#particle" },
"east": { "uv": [ 8.5, 4.5, 10, 6 ], "texture": "#particle" }
"__comment": "Cube13",
"from": [ 7.500376, 14.00105, 13.50077 ],
"to": [ 8.500376, 14.50105, 14.50077 ],
"faces": {
"down": { "uv": [ 15, 9, 14, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 15, 8, 14, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 7, 7, 6.5 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 7, 8, 6.5 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 14, 6.5, 15, 7 ], "texture": "#particle" },
"east": { "uv": [ 1, 6.5, 2, 7 ], "texture": "#particle" }
"__comment": "Cube14",
"from": [ 7.498911, 13.49915, 14.00018 ],
"to": [ 8.498911, 13.99915, 14.50018 ],
"faces": {
"down": { "uv": [ 15, 9, 14.5, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 15, 8, 14.5, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 7.5, 7, 7 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 7.5, 8, 7 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 14.5, 7, 15, 7.5 ], "texture": "#particle" },
"east": { "uv": [ 1, 7, 1.5, 7.5 ], "texture": "#particle" }
"__comment": "Cube15",
"from": [ 7.500244, 12.99945, 14.50042 ],
"to": [ 8.500244, 13.99945, 15.00042 ],
"faces": {
"down": { "uv": [ 15.5, 9, 15, 8 ], "texture": "#particle", "rotation": 90 },
"up": { "uv": [ 15.5, 8, 15, 7 ], "texture": "#particle", "rotation": 270 },
"north": { "uv": [ 8, 8, 7, 7 ], "texture": "#particle", "rotation": 180 },
"south": { "uv": [ 9, 8, 8, 7 ], "texture": "#particle", "rotation": 180 },
"west": { "uv": [ 15, 7, 15.5, 8 ], "texture": "#particle" },
"east": { "uv": [ 0.5, 7, 1, 8 ], "texture": "#particle" }
"__comment": "Cube16",
"from": [ 6.99969, 16.00089, 7.500611 ],
"to": [ 8.99969, 17.50089, 9.000611 ],
"faces": {
"down": { "uv": [ 9.5, 9.5, 8, 7.5 ], "texture": "#texture2", "rotation": 90 },
"up": { "uv": [ 9.5, 8.5, 8, 6.5 ], "texture": "#texture2", "cullface": "up", "rotation": 270 },
"north": { "uv": [ 8.5, 5, 6.5, 3.5 ], "texture": "#texture2", "rotation": 180 },
"south": { "uv": [ 9.5, 5, 7.5, 3.5 ], "texture": "#texture2", "rotation": 180 },
"west": { "uv": [ 8, 3.5, 9.5, 5 ], "texture": "#texture2" },
"east": { "uv": [ 6.5, 3.5, 8, 5 ], "texture": "#texture2" }
"__comment": "Cube17",
"from": [ 6.50027, 16.49983, 7.999809 ],
"to": [ 9.500271, 16.99983, 8.499809 ],
"faces": {
"down": { "uv": [ 9, 10, 8.5, 7 ], "texture": "#texture1", "rotation": 90 },
"up": { "uv": [ 9, 9, 8.5, 6 ], "texture": "#texture1", "rotation": 270 },
"north": { "uv": [ 9, 4.5, 6, 4 ], "texture": "#texture1", "rotation": 180 },
"south": { "uv": [ 10, 4.5, 7, 4 ], "texture": "#texture1", "rotation": 180 },
"west": { "uv": [ 8.5, 4, 9, 4.5 ], "texture": "#texture1" },
"east": { "uv": [ 7, 4, 7.5, 4.5 ], "texture": "#texture1" }
"__comment": "Cube18",
"from": [ 7.499724, 0.4991048, 7.500671 ],
"to": [ 8.499724, 15.4991, 8.500671 ],
"faces": {
"down": { "uv": [ 7.5, 8, 6.5, 7 ], "texture": "#texture", "cullface": "down" },
"up": { "uv": [ 7.5, 9, 6.5, 8 ], "texture": "#texture", "cullface": "down" },
"north": { "uv": [ 7.5, 16, 6.5, 2 ], "texture": "#texture", "cullface": "down", "rotation": 180 },
"south": { "uv": [ 9.5, 16, 8.5, 2 ], "texture": "#texture", "cullface": "down", "rotation": 180 },
"west": { "uv": [ 7, 2, 8, 16 ], "texture": "#texture", "cullface": "down" },
"east": { "uv": [ 8, 2, 9, 16 ], "texture": "#texture", "cullface": "down" }
"display": {
"thirdperson_righthand": {
"rotation": [ -100, 0, 0 ],
"translation": [ 0, 5, -1 ],
"scale": [ 2, 2, 2 ]
"firstperson_righthand": {
"rotation": [ 2, -154, 0 ],
"translation": [ 1.3913, 4.8695, 0 ]
"gui": {
"rotation": [ 139, 63, -139 ],
"translation": [ 0.0009, -0.695, -4.166 ],
"scale": [ 0.9, 0.9, 0.9 ]
"head": {
"rotation": [ -5, 0, 0 ],
"translation": [ 0, 13.913, 0 ]
"ground": {
"rotation": [ 89, -180, 67 ],
"translation": [ 0, 1.393, 0 ],
"scale": [ 4, 4, 4 ]
"fixed": {
"rotation": [ -11, -180, 45 ],
"translation": [ -2.781, 0.6962, -2.782 ]
- AgentZach1
