one element per voxel texture  [Solved]
Post by theismarius » 13 Dec 2016, 21:49
ok so i used to option to convert voxels to elements, but how do i apply all the textures so when exported to minecraft they all appear?
theismarius
Re: one element per voxel texture
Post by Sphax » 13 Dec 2016, 22:12
What is your issue exactly?
Where are you blocked and what are you trying to do?
Also post a screenshot or cubik file of your model
Post by theismarius » 14 Dec 2016, 20:21
http://imgur.com/a/Ke01U
thtas the image, i want all the voxel textures to fit on the texture tag ive squared it in green
theismarius
Re: one element per voxel texture  [Solved]
Post by Sphax » 15 Dec 2016, 10:00
This is not the right conversion method you used.
Why do you want one element per voxel?! That method creates many elements and as many textures as there are colors... this conversion method is useful only with schematic imports or someone who know exactly what he is doing.
Your model is obviously complex and contains many colors. The best method for it is the third (1+ elements per surface and an atlas texture).
Post by theismarius » 15 Dec 2016, 14:55
ok thx :D
theismarius
