Can anyone help me ?
http://prntscr.com/djgs47
http://hastebin.com/yugominaho.json
Problem in-game ! [Solved]
Re: Problem in-game !
You need to be more descriptive of what exactly your problem is. I know and I can see what your problem is, but it might discourage other from helping you because of the lack of explanation.
As for your problem, if I can interpret it correctly, either your display values are wayyy off and you should go into the Preview settings and edit them to your liking, or your display settings aren't getting rendered in game because you did not name them properly.
Your json is for Minecraft 1.8
CubikStudio works with Minecraft 1.9+ for the model and the display settings (and overrides) and 1.8 for the model itself alone
