Show off your models and projects.
Post
by Zaliku » 01 Nov 2016, 20:41
This is my first model created using CubikStudio. I tried to upload it on Sketchfab but the result wasn't that great
So here is an image how it is supposed to look:
I hope you like it
Zaliku
3 x | 1 x
Post
by Sphax » 01 Nov 2016, 22:50
Sketchfab will update default settings for CubikStudio models soon but in the meantime, be sure to set filtering of your textures to "nearest neighbor" and to setup transparency (it's in 3D Settings of your model on Sketchfab). That will make render a lot better
- Admin
70 x | 223 x
Post
by Zaliku » 02 Nov 2016, 10:12
Okay
thanks for the answer
Zaliku
3 x | 1 x
Post
by Zaliku » 02 Nov 2016, 17:04
Now it works perfectly
Thanks for the tutorial how to use transparency! As you see it really helped
Zaliku
3 x | 1 x
Post
by Sphax » 02 Nov 2016, 17:14
A lot better! Added to showcase.
- Admin
70 x | 223 x
Post
by Zaliku » 02 Nov 2016, 17:34
NICE!!! :DD
Zaliku
3 x | 1 x
Return to “Showcase”
