Is there a way to apply a texture to a whole voxel model and/or to each individual voxel?
or just colors?
texture for voxel [Solved]
Re: texture for voxel
I think if you use voxels you can't apply textures but you can convert them to elements and then apply textures to the elements.
Yeah but If you use the right colors straight from the beginning then Cubik automatically creates a texture.
By the way, do not mistake "voxel" and "element" or "cuboid".
Elements are cuboids or planes (which are infact flat cuboids).
Voxels are points in space represented by a colored cube.
Cubik supports both alone or together as well as meshes.
You can create elements and texture each one individually but you can only assign a color to a voxel.
