Problems with voxel coloring (dark brown)  [Solved]
Post by Leonorex » 06 Dec 2016, 19:27
Hey. I have a problem with voxel textures. If i select deep tones of brown a blue square appears around the voxel.. any way to prevent the program from doing so? or do i need to change the textures manually?
Leonorex
Re: Problems with voxel coloring (dark brown)
Post by Sphax » 06 Dec 2016, 20:52
screenshot?
Post by Leonorex » 06 Dec 2016, 21:37
Sorry, forgot about that ...
Link:
http://imgur.com/a/JSNx9
EDIT: And its not only Dark Brown!
Leonorex
Post by Leonorex » 06 Dec 2016, 21:41
Oh, and is there a way to change the body of the "voxel-ABC123" schemes in the Material list?
Leonorex
Re: Problems with voxel coloring (dark brown)  [Solved]
Post by Sphax » 06 Dec 2016, 22:25
border colors are wrong in generated textures for converted voxels to elements with 1st method.
However I think this is not the right method to chose for the thing you want to do.
Post by Leonorex » 07 Dec 2016, 14:23
ok. thank you for your help. :D
Leonorex
