How can I make my 3d models work with versions like 1.7.10 [Solved]
When I try to import the .json file the item just doesn't work (Usually with the gui and hand views) but the texture loads in perfectly fine
- DigitalDebonair
Re: How can I make my 3d models work with versions like 1.7.10 [Solved]
3D models are supported since Minecraft version 1.8.
Oh wow I'm smart, well thank you!
- DigitalDebonair
I have the same question. I have a really old map on 1.7.10 and can't upgrade because of all the mods installed (half the buildings would disappear). I decided to make my own custom models, so I started using Tabula. After a while of trying to make a simple model in it I started to look around for a better solution and eventually bought Cubik yesterday. But I found out that the exported .java files are all messed up in the game.
Is there a way to edit values inside the .java file so it would display correctly or did I just waste $20?
1st: you should have created your own thread. Your subject is very different from the original question...
2nd: Java exporter will be fixed
was it fixed yet? I've tried it again today and the exported model is still all messed up.
