To do so, your BDcraft account should have been migrated to Cubik Studio. However, in some cases, the migration did not happen.
To upgrade:
READ THE WHOLE POST BEFORE ASKING FOR HELP!
Here is the step by step guide to help you with migration:
- Go to the Download page
- If you have a Cubik Pro copy, click on "Login" button
- Enter your BDcraft account Username and password
> If that works jump to step 13
> If that doesn't work, or you somehow never had an account before, continue the guide - Use the recover form
- Enter your BDcraft email in 1st field
- Enter your Cubik Pro Serial in 2nd field
> If you don't know what your Cubik Pro serial is, use the lost Cubik Pro email form - Click "Recover" button and check your email
- When you receive the email, click on "Activate" link
> If already logged in, confirm your password and then jump to step 13 - Try to login as in step 3
> If login works jump to step 13
> If that doesn't work, create a new account
> If creating a new account is impossible because email is already used, use the lost password form and jump to step 13
> If you cannot remember your username use the username recovery form, then use the lost password form and then jump to step 13 - When account created, activate it with the email you received
- When account is activated, login
- Now activate your Serial
- Click on the "Download" button of your choice (Windows, MacOSX or Linux)
Be sure to unzip CubikUpdater in a folder which does not require Admin privileges.
Choose a folder like one on desktop and then launch CubikUpdater and follow instructions.
