Can't launch Cubik Studio on Mac  [Solved]
Post by katango » 19 Nov 2016, 13:04
OSX says, "The application "CubikUpdater.app" can't be opened"
Reason: edited title for better understanding for others with same issue
katango
Re: >:( Cubik Studio for Mac is not working.  [Solved]
Post by katango » 19 Nov 2016, 13:09
Solved!
On terminal:
chmod +x CubikUpdater.app/Contents/MacOS/CubikUpdater
katango
Post by Sphax » 19 Nov 2016, 16:40
That's weird you had to do that... During our tests, only Linux need to do something like that to launch CubikUpdater. CubikUpdater was working straight out of the box.
Glad you figured how to solve the issue though. ;)
Post by Creepinson » 10 Jan 2017, 18:55
katango wrote: 19 Nov 2016, 13:09 Solved!
On terminal:
THANK YOU! :)
Creepinson
Re: Can't launch Cubik Studio on Mac
Post by spapadim » 22 Mar 2019, 13:41
Apologies for necropost (not sure if I should have started new thread..).
In any case, I encountered exact same behavior right now (two years later), and figured out how to replicate.
It seems the issue occurs only if you unzip via terminal, rather than via Finder (in which case, you probably know enough to chmod :)). I unzipped (and then renamed .app dir) once with "unzip cubik_updater_macos.zip" via terminal and again by double-clicking zipfile in Finder, and then I get:
garfield:~/Downloads$ ls -l CubikUpdater-unzip.app/Contents/MacOS/CubikUpdater CubikUpdater-finder.app/Contents/MacOS/CubikUpdater
-rwxr-xr-x@ 1 spapadim  staff  58709020 Nov 24  2016 CubikUpdater-finder.app/Contents/MacOS/CubikUpdater
-rw-r--r--@ 1 spapadim  staff  58709020 Nov 24  2016 CubikUpdater-unzip.app/Contents/MacOS/CubikUpdater
No idea why unzip behaves this way, never noticed something like that before (weird indeed). But, mystery solved!
spapadim
