Voxel Colors  [Solved]
Voxel Colors
Post by Cubix001 » 15 Nov 2016, 18:14
Why when I convert voxels to elements I lose my colors? what is the point in coloring the voxels if you can't use them? I'm sure I'm doing something wrong, but and example or a guide would be helpful.
Because if I have to do it like you use to in cubik pro with texturing every element then it makes studio kinda pointless, please help!
Cubix001
Re: Voxel Colors  [Solved]
Post by Cubix001 » 15 Nov 2016, 20:40
Nvm I figured it out,
Closed.
Cubix001
Re: Voxel Colors
Post by Sphax » 15 Nov 2016, 21:27
Would be nice to always say how you figured out how to solve your issue.
By the way, Im pretty sure you just had to disable the elements tint in Preferences > Display 😉
Re: Voxel Colors
Post by chyx » 16 Nov 2016, 13:10
i met this problem too.
i solve it by adding a new voxel in color i use (then remove it)
chyx
Re: Voxel Colors
Post by Sphax » 16 Nov 2016, 15:33
chyx wrote: 16 Nov 2016, 13:10 i met this problem too.
What you are talking about is a bug which has been solved in version 2.1 (if you have 2.0n re-launch Cubik Updater)
