Video, picture and text guides, in various languages, about how to use Cubik Studio.
Post
by Sphax » 23 Feb 2018, 15:25
Cubik Studio can export a voxel model to "SCHEMATIC" format, commonly used for
Minecraft maps.
To create a schematic in Cubik, follow these simple steps:
A. Setup voxels:
- Go in Voxel edit mode
![Voxel :voxel:](./images/smilies/cubik/cubik_voxel.png)
- Select "..." > "Setup"
- Enter the resolution (size of the middle area) of your voxel world. For example "32" will make the middle zone 32x32x32 and so the whole space 96x96x96
- Click Apply and start creating your voxel model!
B. Model properties:
- Go in your model properties "Model" > "Settings" > "Minecraft"
- Check "Map" type
- By default, the map is already setup with "empty" as air, "default" (unknown color) as stone, #5A9643 (green) as grass and #A46939 (brown) as dirt
- You can add here any color code to become any Minecraft block
- You can also click "Auto list" so Cubik will take all colors in your voxel model and add it to the list. If a color is recognized, it will be automatically associated to right block.
C. Block names:
Minecraft has nearly 256 different blocks. Here is a non exhaustive list you can use in Cubik, the full list can be found here:
https://minecraft.gamepedia.com/Java_Ed ... #Block_IDs
[+] Show
- stone
- grass
- dirt
- cobblestone
- planks
- sapling
- bedrock
- flowing_water
- water
- flowing_lava
- lava
- sand
- gravel
- gold_ore
- iron_ore
- coal_ore
- log
- leaves
- sponge
- glass
- lapis_ore
- lapis_block
- dispenser
- sandstone
- noteblock
- bed
- golden_rail
- detector_rail
- sticky_piston
- web
- tallgrass
- deadbush
- piston
- piston_head
- wool
- piston_extension
- yellow_flower
- red_flower
- brown_mushroom
- red_mushroom
- gold_block
- iron_block
- double_stone_slab
- stone_slab
- brick_block
- tnt
- bookshelf
- mossy_cobblestone
- obsidian
- torch
- fire
- mob_spawner
- oak_stairs
- chest
- redstone_wire
- diamond_ore
- diamond_block
- crafting_table
- wheat
- farmland
- furnace
- lit_furnace
- standing_sign
D. Export!
You know how to export your model. If you finished adding all the voxels you want and you have setup the model properties so each color corresponds to a specific block (otherwise, it will be stone by default):
- Go in File > Export > Select ".schematic" format
- Enter a name for your model/map
- OK!
- Admin
70 x | 226 x
Post
by josevazqm » 01 Mar 2018, 09:38
I tried exporting my element model and the output schematic file was corrupted
josevazqm
6 x | 1 x
Post
by Sphax » 01 Mar 2018, 14:08
josevazqm wrote: ↑01 Mar 2018, 09:38
Yes the bug is known (currently it can only export 16x or lower resolution) and the exporter is fixed for next release.
- Admin
70 x | 226 x
Post
by Nevoska » 07 May 2018, 22:42
Any plans to expand that 16x size? Do you know any programs that converts 3d models with texture to .schematic?
Nevoska
Post
by kangchul » 09 May 2018, 00:42
If you export schematic, the file is corrupted.
It is also possible to send it at 16x resolution.
The error contents are as follows.
keyerror ("key data not found.")
or
valueerror is too small! (0)
is. please answer about my question.
kangchul
Post
by Krose » 06 Aug 2018, 19:10
I've followed these steps and mcedit cannot read the file because it produces a schematic which is 0 bytes.
And i can't see how i can change my "Number of voxels per axis per zone" to below 112.
Could you please let me know how to resolve this? I bought a license for Cubik Studio to convert VOX files (produced by magicavoxel) into .schematic files for import into minecraft worlds. Thanks in advance.
Krose
Post
by Sphax » 03 Sep 2018, 09:27
Krose wrote: ↑06 Aug 2018, 19:10
This will be fixed in 2.10 (no ETA though)
- Admin
70 x | 226 x
Post
by huiAPPOAJ » 18 Feb 2019, 12:49
I have a problem with materials. When I export a model and then try to import it via worldedit it says "Schematic file is missing a "Materials" tag"
When I go to Model properties and Map options, all the materials are assigned correctly.
huiAPPOAJ
1 x
Post
by Need_Not » 06 Mar 2019, 20:24
huiAPPOAJ wrote: ↑18 Feb 2019, 12:49
i have the same thing
Need_Not
1 x
Post
by qqq5715715 » 19 May 2019, 01:34
A year later, when will you upgrade
1 x
qqq5715715
1 x
Return to “Tutorials”
