Textures aren't rendering correctly in MC  [Solved]
Post by Beardlessbrady » 14 Nov 2016, 01:28
Ill use a picture to better explain my predicament.
http://imgur.com/a/5VDjh
Beardlessbrady
Re: Textures aren't rendering correctly in MC
Post by HanFox » 14 Nov 2016, 02:02
Without being able to see the actual JSON I suspect for the faces that are disappearing you have culling on those elements set to Down.
Post by Beardlessbrady » 14 Nov 2016, 02:32
That seems to be the problem thanks! question though, I don't fully understand what culling does, can you briefly explain what it does?
Beardlessbrady
Re: Textures aren't rendering correctly in MC  [Solved]
Post by HanFox » 14 Nov 2016, 02:52
cullface: Specifies whether a face does not need to be rendered when there is a block touching it in the specified position. The position can be: down, up, north, south, west, or east. It will also determine which side of the block to use the light level from for lighting the face, and if unset, defaults to the side.
Source: http://minecraft.gamepedia.com/Model
Post by Beardlessbrady » 14 Nov 2016, 03:13
Thanks
Beardlessbrady
