Cannot open in OS X  [Solved]
Cannot open in OS X
Post by Kirk Markarian » 11 Nov 2022, 13:01
Also tried the "sudo chmod -R 755" (found here on the forum) method, in two different ways. No luck.
Please help me make this open up on Mac Ventura 13.0?
Kirk Markarian
Re: Cannot open in OS X
Post by HanFox » 11 Nov 2022, 18:22
Can you try the steps in this post by Aussi3U53r:
viewtopic.php?p=7693
If that doesn't work I can only really offer you a refund as it may just be that Mac OS has changed so much since the last update that it just won't run without being overhauled.
Post by Kirk Markarian » 11 Nov 2022, 19:03
Unfortunately, those Terminal instructions did not work. I suppose a refund would be in order.
Kirk Markarian
Re: Cannot open in OS X  [Solved]
Post by HanFox » 11 Nov 2022, 19:12
I see.
I have requested a refund for you. It should be processed within 48 hours. If you don't receive it please let us know.
Sorry for the inconvenience.
Post by Kirk Markarian » 11 Nov 2022, 19:17
Thank you for your understanding!
Kirk Markarian
