Hello,
I currently have a problem. When the Cubik update is done, I cannot access cubikstudio. I run cubikstudio, I cannot use it but the icon is in the taskbar...
I am under Win64. Anyone know how to fix this?
Thanks
Can't open Cubikstudio win64 [Solved]
- SnoopyDodo
Re: Can't open Cubikstudio win64
Make sure your Visual C++ is up-to-date: https://support.microsoft.com/en-gb/hel ... -downloads
Even with an update nothing changesHanFox wrote: 07 Nov 2020, 15:18 Make sure your Visual C++ is up-to-date: https://support.microsoft.com/en-gb/hel ... -downloads
- SnoopyDodo
You can try each of these to see if it helps:
- Whilst the program is open select it in the taskbar then press Windows key + an arrow key
- Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
- Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
The last solution workedHanFox wrote: 11 Nov 2020, 11:35 You can try each of these to see if it helps:
- SnoopyDodo
