Version:2.9.480
Problem:When I set LeftControl for the rotating keybinding, the keybinding can't be used after the next startup of Cubik but until I reconfirm the settings.
I think there's a conflict with the multi-select keybinding, but there seems to be no way to change that.
This keybinding is important as it is the default keybinding of the older version of the Cubik! And the number-based keybinding isn't convenient to use.
Hotkey Bug when setting LeftControl to rotate keybinding [Solved]
- Blue_Beaker
- Likes: 1 x
Re: Hotkey Bug when setting LeftControl to rotate keybinding [Solved]
Sorry for the issue.
This is a known bug and is fixed in next version.
