Voxel to element color mess up  [Solved]
Post by RiCkYB_667 » 02 Jun 2018, 22:49
Hi there!
Could anyone please help how could i avoid the colors messing up when creating elements from voxels?
I tried both palette and atlas methods, but no luck.
Or if this should happen, what are the next steps to regain the "original voxel colors"?
I need them to be elements so i can make the blade translucent.
Thanks for the help!
RiCkYB_667
Re: Voxel to element color mess up
Post by Cookiesnom » 03 Jun 2018, 23:56
You just need to disable element shading or set all of the element shades to white.
Cookiesnom
Re: Voxel to element color mess up  [Solved]
Post by RiCkYB_667 » 04 Jun 2018, 20:31
Oh that's neat. I must have missed that setting.
Anyways i found that ingame it looks just fine.
RiCkYB_667
Post by Sphax » 08 Jun 2018, 17:58
And knowing you are using "Noise", you should convert your voxels with Atlas (not palette) to discrease number of elements.
