Hello, is it possible to import a cubik model into an existing one?
For example, lets say a made a model of a sword, and not I want to import it into another model i'm making (for example, a block) and I want that sword to appear on top of the block. Instead of having to remake the sword model over again it would be much easier to just import it into the model of the block im working on and re-use it
Is this possible to do?
Import model into existing model? [Solved]
- robotnikman
- Likes: 1 x
Re: Import model into existing model? [Solved]
It's possible, yes.
Open one of your models then go to the File menu and select the Merge option and then select the second model.
You can then select all the elements from the second model in the elements panel and position them correctly.
