How to rotate Elements?? [Solved]
I have been playing around with Cubik Studio, and I found that I can't rotate elements with the typical Ctrl+LMouse. How do you rotate the elements now?
Re: How to rotate Elements?? [Solved]
You have to add it back into your preferences.
Then when you restart cubik you have to put a space after them to reset it, so it will work again.
Otherwise you can just use the number 2. but it isant the easiest to handle and doing what stated above isant too hard.
- Cookiesnom
- Likes: 4 x | 9 x
