I can't open the program.  [Solved]
Post by Murasaki_Hotaru » 17 Dec 2017, 07:50
I opened the program but nothing happened, which is the icon in the taskbar.
Murasaki_Hotaru
Re: I can't open the program.
Post by CaptainGalax » 17 Dec 2017, 14:39
It's a standard Problem.
Right click on it and choose "Maximize" that should fix it.
CaptainGalax
Post by revmc » 21 Dec 2017, 09:02
I'm having the same problem but I can't maximize because there is no option in Windows10 for that.
revmc
Re: I can't open the program.  [Solved]
Post by HanFox » 21 Dec 2017, 09:17
There are a few ways to solve the issue:
  1. Try holding alt whilst the program is opening (white/black screen)
  2. Whilst the program is open select it in the taskbar then press Windows key + an arrow key
  3. Whilst the program is open select it in the taskbar and press Alt+Space and select "Maximize" from the menu that should appear in the top left of your screen
  4. Go to C:\Users\<user>\AppData\LocalLow\BDcraft\Cubik and edit cubikdata.json so that "windowX" and "windowY" are 0
Post by revmc » 22 Dec 2017, 01:30
Thanks.
revmc
Post by Murasaki_Hotaru » 29 Dec 2017, 19:42
Thank you.
Murasaki_Hotaru
