Invisible areas under custom blocks, how to remove? [Solved]
how do you make it so that there aren't invisible areas under a custom block like here
- Frostyhobo47
Re: Invisible areas under custom blocks, how to remove?
I reccomend making the model bigger, because its smaller than a normal block
Re: Invisible areas under custom blocks, how to remove? [Solved]
Only "transparent" blocks can have any kind of 3D model.
Solid blocks can't have a see-through 3D model.
Example:
Logs are solid block
Stairs are transparent blocks
Example:
