Back Up [Solved]
Back Up
So I was working on a project and had another one open at the same time, My computer crashed so I loaded up my back up, the back up was only the one I was looking at and not the one I needed / was working on. Can I get the other one back its really important.
Re: Back Up [Solved]
Sadly, the backup system is not designed to be unique per Cubik instance. I'm afraid you can't get your work back if you've not saved it anywhere.
For information: The backup system is designed to save every 10 minutes (by default) the model you are working on and it keeps only one backup per day of the week (= 7 backup)
