Hello, I always have a question that would help me A LOT.
I would like to know if it was possible to select several cubes at a time so as to copy paste.
I'm sorry if the answer to already was said because I do not speak English and I use google translation.
How to select multiple cube at a time? [Solved]
Re: How to select multiple cube at a time? [Solved]
You can select multiple elements with several ways:
- Right Ctrl + left click on each element
- Right Shift + left click pressed to draw a selection rectangle in 2D views
- Ctrl+A to select all elements
- Elements or Meshes list with Right Ctrl or Shift
Thanks !Sphax wrote: 08 May 2017, 15:56 You can select multiple elements with several ways:
Simple but effective. Map creator
