MC Compatible?  [Solved]
MC Compatible?
Post by xxStaten » 24 Apr 2017, 19:22
So it's been a while since I've played Minecraft, since 1.8. It's also been that long since I've used Cubik and since then, it's changed dramatically, it's awesome. But I remember last time I did all this, I remember the more "cubes", the more lag. Now I see the program does voxels and much more. Minecraft can handle all this now?
xxStaten
Re: MC Compatible?
Post by Crimed » 26 Apr 2017, 04:52
They use the magic file, called .json, very cool. opens up alot more doors without mods now
Crimed
Re: MC Compatible?  [Solved]
Post by CaptainGalax » 26 Apr 2017, 18:51
xxStaten wrote: 24 Apr 2017, 19:22 So it's been a while since I've played Minecraft, since 1.8. It's also been that long since I've used Cubik and since then, it's changed dramatically, it's awesome. But I remember last time I did all this, I remember the more "cubes", the more lag. Now I see the program does voxels and much more. Minecraft can handle all this now?
Yes, it can lag. More cubes = longer .json file = longer load = frame drops.
Sphax added for this a function called "Optimize" at Element --> Optimize, this only work if you have converted the voxels to cubes.
Deutsch:
Ja, es könnte zu Lags führen. Mehr Würfel = größere .json Datei = Längeres laden = Bild-drops.
Sphax hat dafür eine Funktion mit dem Namen "Optimize" hinzugefügt. Bei Element --> Optimize, das funktoniert nur wenn du die Voxels zu Würfeln conventiert hast.
A friend called "Zachrywilsn" created a Skype group, where you can get help about Cubik/Modeling!
https://join.skype.com/FYDIkTjfY2wj
CaptainGalax
