Textures Won't Load In Minecraft  [Solved]
Post by HealableHades1 » 19 Feb 2017, 02:27
When I export my json file to my resource pack and then use it in minecraft, there is no texture to it.
HealableHades1
Re: Textures Won't Load In Minecraft
Post by HanFox » 19 Feb 2017, 02:35
Make sure all your folders and filenames are lowercase.
Post by HealableHades1 » 19 Feb 2017, 03:49
All my filenames and folders are lowercase and it still doesn't load.
Here is the download for the pack
https://drive.google.com/file/d/0B9ZA_- ... sp=sharing
It is a pumpkin by the way
HealableHades1
Re: Textures Won't Load In Minecraft  [Solved]
Post by HanFox » 19 Feb 2017, 12:11
You haven't defined the path to your textures correctly.
Also, in the future, if you want help you might want to actually just share the relevant files instead of a slightly edited vanilla pack which anyone who wants to help has to pick through to find the right files...
