Open Multiple Models  [Solved]
Post by Jimmy » 05 Dec 2016, 19:16
Hey there, so I've created two models separately, an inkwell and a scroll. They're each their own json files now. I'd like to actually combine them into one file, so how can I open both models in Cubik? When I open one, it replaces the other. I've tried using import, but it has the same effect. Any help is appreciated!
Jimmy
Re: Open Multiple Models
Post by CaptainGalax » 05 Dec 2016, 19:22
Jimmy wrote: 05 Dec 2016, 19:16 Hey there, so I've created two models separately, an inkwell and a scroll. They're each their own json files now. I'd like to actually combine them into one file, so how can I open both models in Cubik? When I open one, it replaces the other. I've tried using import, but it has the same effect. Any help is appreciated!
Try to export the models as .OBJ and import it.
CaptainGalax
Re: Open Multiple Models  [Solved]
Post by HanFox » 05 Dec 2016, 19:36
Open one model in Cubik then File > Merge (Ctrl+M) and select the other model.
Post by Jimmy » 05 Dec 2016, 23:22
Thanks guys!
Jimmy
