Hello,
I can not use my serial numbers anymore for the software cubik studio or cubik pro or animaker and can not reset the serial number.
can i to get another key so that I can use the software again.
Yours sincerely
Simon
i don't can use serial keys and i don't can reset this [Solved]
Re: i don't can use serial keys and i don't can reset this
Your key doesn't have any uses against it currently.
What's the error you're actually seeing?
The problem is that I always used the key to register with the software and it does not work anymore
"does not work anymore" is not an error I can work with. You need to tell me the actual error.
if I try to register with cubik pro yes I need my email and the serial number and the serial number you always entered has not worked anymore (which has no use) how can I log in again in cubik pro?
Now I have a new problem now he says that he has lost the internet connection
I have found the problem for what it decisively for the moment there is no solution.
This is my problem:
viewtopic.php?f=2&t=2117&p=6585&hilit=offline#p6585
This is my problem:
Re: i don't can use serial keys and i don't can reset this [Solved]
In another thread someone said they had success by using a VPN.
