BDcraft Cubic Pro is unable to discuss with http://cublik.studio.  [Solved]
Post by 007gadgetcookie1 » 30 Aug 2019, 10:26
I dont know what im doing wrong but i put in my account email and my code and then it keeps on coming up with
BDcraft Cubic Pro is unable to discuss with https://cubik.studio.
007gadgetcookie1
Re: BDcraft Cubic Pro is unable to discuss with http://cublik.studio.
Post by HanFox » 30 Aug 2019, 11:16
Generally this seems to be an issue with a local firewall/router. We don't actively block anything at our end so you'll need to try and troubleshoot your network.
Post by 007gadgetcookie1 » 30 Aug 2019, 11:49
what would i need to do in local firewall in order to see if i can fix the issue there
also just letting you know i have put the file folder location on the homescreen so is that probs the reason ?
007gadgetcookie1
Re: BDcraft Cubic Pro is unable to discuss with http://cublik.studio.  [Solved]
Post by HanFox » 30 Aug 2019, 11:54
All the requests should be served over port 443 (https).
It's possible that the application itself is being blocked.
I am unable to really help you with specifics as have never had the issue.
