Key uses hit limit when I reinstall system and change computer  [Solved]
Post by Blue_Beaker » 29 May 2019, 14:19
I changed my computer and the key uses hits limit.
Then I couldn't register cubik studio on my new tablet.
Before this, I used cubik studio on a laptop and reinstalled system and reactivated cubik studio. Now I don't use that laptop anymore.
And I also activated cubik studio on a desktop computer which I always use.
Then I got a new tablet and the key hits limit.
Please add a way that we can transfer and manage licenses without resetting license. Resetting key is too inconvenient, especially for users that often changes computer or reinstalls system.
I think you can use Microsoft's device management system as reference.
Blue_Beaker
Re: Key uses hit limit when I reinstall system and change computer  [Solved]
Post by HanFox » 29 May 2019, 14:39
Most users do not change systems frequently enough to trigger the key limits.
It should also be noted that the key uses are automatically fully reset in a fairly short period of time (roughly a year -- most people wouldn't have changed PCs and tablets within that period more than once, if at all).
Moreover, the current system is a good way to remind people not to abuse their keys by installing it on a large number of devices, or sharing it with other people. Which are both things you agreed you wouldn't do when agreeing to the Terms of Use.
Maybe if it becomes more of an issue a different system may be considered.
