key problem with uses again same pc.  [Solved]
Post by Aukister » 22 Aug 2018, 17:01
:\ key uses once again, gets quiet annoying..
Aukister
Re: key problem with uses again same pc.  [Solved]
Post by HanFox » 24 Aug 2018, 09:43
You're only meant to use the key on one or two computers, and you're not allowed to share it with others.
If you're constantly formatting your computer this is also considered a new system (due to how Windows generates that sort of information), so if you are formatting don't install Cubik until you're happy with your setup.
I have reset your key again on this occasion.
