Request a reset key  [Solved]
Request a reset key
Post by 郭萌皓 » 20 Aug 2018, 15:37
Dear HanFox (or other administrators...) ,
Me the other day when working with the factory's laptop have landed cubik, don't do it now, come home, because home computer is bad, I have to go to the Internet cafe to use the software, I always want to go to Internet cafes are not way, looking back I keep their computers replace system want to make do with, but I found that has not been on board, the discord ask know after multiple computers using key will record the IP can only be reset key, so I beg you to help me to reset the key.
Thank you for your
GuoMengHao
郭萌皓
Re: Request a reset key
Post by HanFox » 20 Aug 2018, 15:41
Your key doesn't currently require resetting as it still has uses left.
Post by 郭萌皓 » 21 Aug 2018, 05:32
Why is that?
郭萌皓
Post by 郭萌皓 » 21 Aug 2018, 05:39
The same thing happens when you start the software. The key is all right, but OK can't be clicked
Reason: Removed image
郭萌皓
Re: Request a reset key  [Solved]
Post by HanFox » 21 Aug 2018, 10:41
Make sure you're entering the information correctly from https://cubik.studio/get
Make sure your computer's clock is set correctly.
If you're behind a proxy make sure it is set up correctly.
Post by 郭萌皓 » 21 Aug 2018, 17:40
Thanks, we have solved it. The original clock should be set correctly
郭萌皓
