Dear HanFox (or other administrators...),
I just moved to a new place, will never use the old PC again so I want to reset the key, so that I can register the key on the new PC in the new place.
I know that THIS IS THE 3rd TIME I ask you for resetting the key license. I know that I can only reset the key for ONLY 1 TIME (2 if for special occasion). So I hope you can accept my exception for this occasion and reset my key FOR THE LAST TIME. If you don't accept it, it's fine...
Thanks you for your time.
NgXTruongHai
Key Reset [Solved]
- NgXTruongHai
Re: Key Reset [Solved]
I have reset your key uses.
Try not to use them all up again so soon
