Post
by andrew » 30 May 2018, 14:42
My cubik studio is not working while registering some proxy connect aborted issue. would it be ok if I could refund it and start again so that I would have a new serial# . I have not been able to use the version I have right know so I'm hoping this could be a possibility-Thanks
Andrew
andrew
Post
by HanFox » 30 May 2018, 15:14
You need to Google how to fix your proxy settings. A new key will not solve your issue. You've proven your key works fine on other computers.
Sphax even pointed you in the right direction previously:
viewtopic.php?f=2&t=1677#p5656
- Web Admin
30 x | 76 x
Post
by andrew » 30 May 2018, 17:18
alright I'll try again thx ..... u guys r probably so fed up with me right know sorry
andrew
