my friend has clean windows and HWID has been changed
: paompz374
Please Reset My Serial Key [Solved]
Re: Please Reset My Serial Key
Your key was reset on the 9th April already.
Please also be aware you cannot share your key with anyone.
Yes i request 9 April and my friend has cleaned windows
What do you mean your friend has cleaned Windows?
You used all your activations in less than 3 weeks.
Even if you had to reinstall your PC that's only 2 uses.
You need to explain exactly what has happened. Feel free to post in your native language.
i dont know what i can say
My Frield has reinstall windows because it has Problem about Program
and then HWID has been changed
i can use only 1 computer
but my friend can't use because old HWID has been changed
Re: Please Reset My Serial Key [Solved]
As I already told you you can't share your key with your friends. It says so in the Terms of Use.
Your key has already been reset recently. It won't be reset again as you've breached the Terms of Use.
