Key usage reset  [Solved]
Key usage reset
Post by SunPixel » 16 Apr 2017, 10:31
I would also like to move to new pc and I can't just use the key twice What should i do
SunPixel
Re: Key usage reset  [Solved]
Post by Sphax » 17 Apr 2017, 09:18
You don't need to ask for a reset even before having a problem. Just move to another PC if you want, use your Serial and Username and see if that works.
Then if that doesn't work, just tell us here. ;)
