"Serial used by too many different users!"  [Solved]
Post by TheMajorMushroom » 18 Nov 2016, 07:32
Trying to update Cubik Studio and it gives me the above warning. Pretty sure I haven't given my BDCode to anyone else :p so don't know why it's doing this. I'm majormushroom42{at}gmail{dot}com. Thanks for the great software :cubik:
Currently working for the #PokeCA project with @phnixhamsta :D
TheMajorMushroom
Re: "Serial used by too many different users!"
Post by Sphax » 18 Nov 2016, 08:16
Are you using Cubik Studio on different machines ?
Post by TheMajorMushroom » 18 Nov 2016, 09:18
Nope, just on my personal laptop. I suppose it's possible one of my friends saw it and wanted to try it out, but I didn't do so myself.
TheMajorMushroom
Post by TheMajorMushroom » 18 Nov 2016, 09:22
In any case, might be easiest if you just replace my code. I'm not sure what went wrong, might well have been one of my scumbag friends -_- but I'm happy with whatever works. :)
TheMajorMushroom
Re: "Serial used by too many different users!"  [Solved]
Post by Sphax » 18 Nov 2016, 17:46
Please remember that by downloading CubikStudio you agreed with the Terms of Use and they say the following:
By using Cubik Studio, you know that you ARE NOT authorized to:
Communicate your Serial to anyone. If a Serial [...] is used by more than one user on more than one machine, it will be automatically banned and the attached product will become unusable.
I will reset your license but if anything goes wrong again, it will just stay as is (i.e. blocked).
Let me know if it worked, also you should re-download and reinstall it.
Post by TheMajorMushroom » 18 Nov 2016, 22:04
Yes, it worked fine. My apologies for wasting your time, and thanks again for making this great software :cubik:
TheMajorMushroom
Post by TheMajorMushroom » 20 Nov 2016, 08:36
UPDATE - nobody I knew had taken the code or used it, so not sure why I had this problem. Must have been a problem on your end, just thought I'd check in.
TheMajorMushroom
