Export models as ". schematic"  [Solved]
Post by Nevoska » 02 Nov 2017, 21:22
How abought a way to export models as ". schematic". Tthe program matches each voxel color with a minecraft block and generates a MCedit file that you can put in your world.
You would be able to select which blocks you want and size of the construction.
Nevoska
Re: Export models as ". schematic"  [Solved]
Post by Sphax » 10 Nov 2017, 10:51
That has already been suggested and has been added for 2.9 ;)
Post by JTK222 » 10 Nov 2017, 23:43
Could you then maybe think about adding also support for the blueprint format?
(A more mod friendly version of schematics http://dark-roleplay.net/other/blueprint_format.php)
JTK222
Post by MasterClaus » 16 Jan 2018, 13:08
Sphax wrote: 10 Nov 2017, 10:51 That has already been suggested and has been added for 2.9 ;)
Where is the 2.9 changelog
MasterClaus
Return to “Suggestions”
