- Rotate mode : to rotate selection (of elements and/or meshes)
- Scale mode : to scale selection
- Clone mode : to duplicate selection
- Pan view : to move the view with mouse
- Focus view : to make the camera look at and turn around point where the mouse cursor is on
For any command listed, you can customize the key(s).
In Tools > Preferences > Advanced, then in the field corresponding to the command you want to customize the key(s), enter the key name you want to use. You can enter up to 4 different keys separated with a comma.
For example for the Alt key, you can enter "LeftAlt" and "RightAlt".
Generic keys
- Backspace : The backspace key.
- Delete : The forward delete key.
- Tab : The tab key.
- Clear : The Clear key.
- Return : Return key.
- Pause : Pause on PC machines.
- Escape : Escape key.
- Space : Space key.
- UpArrow : Up arrow key.
- DownArrow : Down arrow key.
- RightArrow : Right arrow key.
- LeftArrow : Left arrow key.
- Insert : Insert key key.
- Home : Home key.
- End : End key.
- PageUp : Page up.
- PageDown : Page down.
- All letters (A, B, C, ..., Y, Z)
Numbers (alpha and keypad)
- Alpha0 : The '0' key on the top of the alphanumeric keyboard.
- Alpha1 : The '1' key on the top of the alphanumeric keyboard.
- Alpha2 : The '2' key on the top of the alphanumeric keyboard.
- Alpha3 : The '3' key on the top of the alphanumeric keyboard.
- Alpha4 : The '4' key on the top of the alphanumeric keyboard.
- Alpha5 : The '5' key on the top of the alphanumeric keyboard.
- Alpha6 : The '6' key on the top of the alphanumeric keyboard.
- Alpha7 : The '7' key on the top of the alphanumeric keyboard.
- Alpha8 : The '8' key on the top of the alphanumeric keyboard.
- Alpha9 : The '9' key on the top of the alphanumeric keyboard.
- Keypad0 : Numeric keypad 0.
- Keypad1 : Numeric keypad 1.
- Keypad2 : Numeric keypad 2.
- Keypad3 : Numeric keypad 3.
- Keypad4 : Numeric keypad 4.
- Keypad5 : Numeric keypad 5.
- Keypad6 : Numeric keypad 6.
- Keypad7 : Numeric keypad 7.
- Keypad8 : Numeric keypad 8.
- Keypad9 : Numeric keypad 9.
- KeypadPeriod : Numeric keypad '.'.
- KeypadDivide : Numeric keypad '/'.
- KeypadMultiply : Numeric keypad '*'.
- KeypadMinus : Numeric keypad '-'.
- KeypadPlus : Numeric keypad '+'.
- KeypadEnter : Numeric keypad enter.
- KeypadEquals : Numeric keypad '='.
Special keys
- RightShift : Right shift key.
- LeftShift : Left shift key.
- RightControl : Right Control key.
- LeftControl : Left Control key.
- RightAlt : Right Alt key.
- LeftAlt : Left Alt key.
- LeftCommand : Left Command key.
- RightCommand : Right Command key.
Mouse buttons
- Mouse0 : The Left (or primary) mouse button.
- Mouse1 : Right mouse button (or secondary mouse button).
- Mouse2 : Middle mouse button (or third button).
- Mouse3 : Additional (fourth) mouse button.
- Mouse4 : Additional (fifth) mouse button.
- Mouse5 : Additional (or sixth) mouse button.
- Mouse6 : Additional (or seventh) mouse button.
