Hello, how do I put a texture under the model? And if possible can I make it so its not a specific texture but takes the one of the current block its sitting on?
Also is there a way to remove the shade on the top of the model? (image below)
Thanks in advance!
No texture under the model [Solved]
Re: No texture under the model [Solved]
Minecraft culls the faces of certain blocks. It's hard-coded depending on what you put on top.
If you want to make a model that doesn't fill the entire face like that you need to use a block that supports transparency, such as Stained Glass.
