We have problems starting cubik studio on ubuntu linux version:
4.4.0-72-generic #93-Ubuntu SMP Fri Mar 31 14:07:41 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
we get the following output when starting 'cubikupdater.x86_64':
Set current directory to /home/lukas/Downloads
Found path: /home/lukas/Downloads/cubikupdater.x86_64
Mono path[0] = '/home/lukas/Downloads/cubikupdater_Data/Managed'
Mono path[1] = '/home/lukas/Downloads/cubikupdater_Data/Mono'
Mono config path = '/home/lukas/Downloads/cubikupdater_Data/Mono/etc'
displaymanager : xrandr version warning. 1.5
client has 3 screens
displaymanager screen (0)(LVDS1): 1366 x 768
Using libudev for joystick management
Importing game controller configs
Do you have some suggestions?
Problems starting Cubik Studio on Ubuntu Linux [Solved]
Re: Problems starting Cubik Studio on Ubuntu Linux [Solved]
The pasted output is standard.
The program is fully bundled (i.e. it doesn't rely on other libraries besides the ability to display graphics).
If you can run other Unity applications Cubik should work, too.
You may want to delete any unity3d/Cubik folders you can find within your home folder (.cache/.config/etc.).
