UV mapping on .obj imports  [Solved]
Post by GlobbyLikesSlime » 06 Nov 2016, 22:28
when I import a .obj file and then convert to elements the texture doesn't map with all the elements and it looks weird. When I select all elements then go to UV settings and turn on UV snap, only 1 element gets effected. I don't want to have to select every element individually. Is there a way to fix this?
GlobbyLikesSlime
Re: UV mapping on .obj imports
Post by Profyle » 06 Nov 2016, 22:32
Can you give some more details?
Basically what I'm getting from this is that you import an .obj with an MTL connecting textures to the .obj. You then proceed to convert the .obj to voxels and then further down to elements.
From this I have no idea what you're talking about. Mind sharing something like a few screenshots, a gif, or even a video if you have the chance?
Thanks.
Profyle
Re: UV mapping on .obj imports  [Solved]
Post by GlobbyLikesSlime » 08 Nov 2016, 03:30
Never mind, I found a solution. Thanks anyways ;)
GlobbyLikesSlime
