Changelog: version 2.7
Posted: 23 May 2017, 17:32
We've been pretty busy lately but no worry, Cubik Studio will never be forgotten and I am proud to show you this new update!
Version 2.7 contains ton of new things, including some which were asked for a long time!
Using Cubik Studio will be a lot easier thanks to the camera flip (right click on label), faster with its new torus primitive (Mesh edit-mode), accurate with improved voxelization, handy with the new edit button to modify a texture in your favorite picture editor, customizable with the new dark skin and so much more powerful with the 2 new exporters ("MCPE" and "JAVA Mod" formats to model entities)...
New features and improvements:
Bugs:
Better detection if imported model is block or item and default to block if type is unknown
Better texture shortcut support in Elements Material
Default name of element is now "Box"
New function to automatically sort transparent elements (avoid weird renders in game with transparency)
Added "Edit texture..." menu in Elements Material list popup
New button in UV Mapping editor to edit texture in external editor
New option in Preferences to select Texture Editor executable
New paint tool "Brush square"
Added "L" and "R" labels to selected colors in palette
Custom palette picture is now limited to 16x32 colors
Bounding box visible on primitives when selected
New Torus primitive for Mesh edit-mode
New voxel tool to "select" group of voxels by wrapping automatically blueprint around
New voxel tool "Shell" which adds voxels all around group of collateral voxels
Voxel tools are now using right color when right clicking
Added angle parameter to arms and head in Display settings to modify rotation of arms and head in 3rd person view
Removed character preview animation
New option for PNG importer to import picture as a sprite (billboard mesh which can then be voxelized)
Implemented MCPE Entity Exporter
New "Dark UI" can be selected in preferences
Right clicking on a view label will reverse the point of view (Up > Down, West > East, South > North)
New "Rainbow UI" or maybe not...
Added new options in Model properties for Minecraft Entity type
Implemented JAVA Exporter
Added Ctrl+D to deselect
Added Ctrl+Shift+I to inverse selection
New select by name command (now usable with F3)
Improved rename command for elements and meshes
Change F1, F2, F3 keybinds (cubik forum, rename, select by name)
Better File selector dialog extension filter
Added x86 or x64 in About Box
Error message when no element in model for MCPC JSON, MCPE JSON, Optifine JPM, MC Mod JAVA format exporters
Added and modified several tooltips for better explanation
Despite some things added some covfefe
- Fixed bug with bleeding fill inside mesh during voxelization
- Fixed bug with large or high texture in Textures UV editor (too large horizontal scrollbar or too short vertical scrollbar)
- Fixed old bug which prevented the UV to be refreshed when UV editor was opened for the first time
- Fixed unique ID for elements in JPM Exporter
- Fixed bug to convert voxel colors to texture atlas (voxel color alpha is not used anymore for texture atlas)
- Fixed bug with JSON exporter when last element is hidden and hidden elements are ignored
- Fixed bug with comma in JSON exporter
- Fixed bug with Meshes list not cleared after voxelization
- Fixed potential bugs due to not invariant culture
- Fixed bug when Emptying texture
- Fixed bug with default save texture path
- Fixed bug with offset of dropdown list on Hidpi screens
- Fixed bug with cross button in filter input field which did not work if filter was not validated
- Fixed bug which was minimizing views when 3D view was maximized and edit-mode was changed
- Fixed bug with button "Resize mesh to fit middle zone" which was setting origin to wrong coordinates
- Fixed loading custom palette with alpha
- Fixed covfefe as well
