Page 1 of 2
How to Apply/Use Textures...?
Posted: 03 Nov 2016, 03:35
by Jimmy
So I've just created a sword using voxels and I've colored the voxels accordingly. When I go to export it as .json for Minecraft, it tells me I don't have a texture on it. Is there a way to have the predefined colors you used during creating it be "mapped" as a texture, or will I have to use a 3rd party program to create a texture and have to figure out how to UV map this? Thanks!
Re: How to Apply/Use Textures...?
Posted: 03 Nov 2016, 04:46
by AGearBeast
You need to convert the voxels to elements. Click the ... on the voxel tab and click convert
Posted: 03 Nov 2016, 05:29
by Jimmy
ExMrsDarn wrote: 03 Nov 2016, 04:46
I believe I did that, but then the whole thing just turned black. None of the colors stayed. I'm kinda new to modeling
Posted: 03 Nov 2016, 07:42
Maybe post a screenshot of your model in voxels and a screenshot of the model after conversion to elements?
Posted: 03 Nov 2016, 19:17
by Jimmy
Sphax wrote: 03 Nov 2016, 07:42
Alrighty. So the colored is when it's in "voxel mode". The blacked out is when I convert it to elements.
Posted: 03 Nov 2016, 20:58
How does the textures in Material Manager look like?
Posted: 03 Nov 2016, 21:11
by Jimmy
Sphax wrote: 03 Nov 2016, 20:58
Here's the material manager before converting voxels to elements, and after. The after has the "voxel_palette". Reading that, I'm guessing there's a way to save the palette and then somehow that becomes its texture? Also, would it be possible to record like a 10 minute video just running through the basics and such? It'd be very helpful
Posted: 04 Nov 2016, 08:38
by AGearBeast
i had that problem before when i was first trying the program, but havent had it since. anyways i dont think i could find a fix to keep the texture. So i just created a atlas with blank textures. may not be that helpful if thats not what your wanting to do though.
Posted: 04 Nov 2016, 18:43
by Jimmy
ExMrsDarn wrote: 04 Nov 2016, 08:38
What's an "atlas with blank textures"? haha. Sorry, very new to this program.
Posted: 05 Nov 2016, 02:54
by AGearBeast
Click the ... on the element material window. It will be listed there. Atlas is pretty much just a texture map
