Animation Tool
Posted: 30 Dec 2016, 11:18
Tool type: Voxel
Tool name: Animate
Tool icon: Videotape with letters A, B and C
[+] Show
Tool short description:
This tool lets you animate voxels.
Upon clicking on the tool a timeline would show up on the bottom of your screen.
On top of your time line you will have a couple of buttons like "Add keyframe", "Remove keyframe", etc...
Per frame you can create new voxels and you can pain voxels separately as well.
You can change the FPS (Frames Per Second) when you go into the ... at the top right of the timeline
Tool action on Left click:
When you left click a voxel it would highlight/select the voxel, you can select multiple voxels by pressing Shift + Left click
When you select your voxels, XYZ arrows will pop up and you can move your voxels by doing this. Keyframes are automaticly added so first move on your time line and then move your voxels.
Tool action on Right click:
When you right click on a highlighted/selected voxel you will deselect the voxel.
Tool action on Middle click:
When you click and hold middle mouse button you can move on the timeline.
Tool name: Animate
[+] Show
