Page 1 of 2
Tip:How to make a hexadecagon
Posted: 11 Dec 2016, 11:04
by akkechi
Part1 Beginner
Part2 Little polygon
Part3 tubes
※It is not perfect, but if you do not have a preference, this is enough.
Re: Tip:How to make a hexadecagon
Posted: 11 Dec 2016, 12:35
A way which would produce less polygons is by using same technique but positioning origin on the middle of each element (instead of border).
Also, before rotating elements, be sure to remove hidden faces to create less polygons.
Posted: 11 Dec 2016, 12:50
by akkechi
Sphax wrote: 11 Dec 2016, 12:35
I also do a method to decide the rotation axis, but I chose an easy method.
Posted: 11 Dec 2016, 13:17
That's cool to see such video in a short format. The 1st method is nice to create tubes and second to create cylinders.
The 2 videos you made are showing how easy it is now to rotate elements thank to v2.4.
Posted: 11 Dec 2016, 13:40
by Geenium
You can increase the accuracy of the shape by using 5.028 instead of 5 for the length of elements, this way the elements will line up much better with each other.
Posted: 11 Dec 2016, 13:58
by akkechi
Sphax wrote: 11 Dec 2016, 13:17
I made a video in Part 3.
Posted: 11 Dec 2016, 14:07
by CaptainGalax
btw, a Hexagon & hexadecagon is planed for my Addon!:)
Posted: 11 Dec 2016, 16:24
CaptainG4laxy wrote: 11 Dec 2016, 14:07
Your addon is using meshes. The videos @akkechi made are useful if users want to keep the clean/smooth/lowpoly aspect which can't be get after a voxelization.
@akkechi your 3rd video is private
Posted: 12 Dec 2016, 02:14
by akkechi
Oh, Sorry ... I released it now.
Posted: 21 Feb 2017, 16:49
by Vexilius
Here's a
template I made.
